230 hydraulic pump removal
luckyfarms
New User
I'm making a 230 into a puller. I removed the fast hitch and lines. I would like to remove pump. Can i just remove it and plate it. Did they make a factory plate that i could use? Also can i just remove the lines from the reservoir and leave it as i think it looks nicer with it and i don't need less weight. Thanks
By the way I just stripped a single front wheel
Super C and replaced the engine with a C-153.
Total weight of tractor stripped of everything
hydraulic related and the pto shaft.
2940 LBS.
Thanks for the info. Around here I will pull 3500 like my super c. The 230 was all rebuilt with high compression pistons, then parked for ten years. Seems to run good so i want to try it. I have a c-153 with flywheel done and 140 fan tucked away that it might get over winter. Also just picked up a 240 just for the new 12.4 firestones that runs great. Plenty of parts and motors to build a decent 230. Should be enough to keep me busy over winter. I just thought that my 153 might have a plate that i could rob for now, i'll have to look
i have a beautiful 230 front grill insert.fiberglass/light weight.new ones on ebay are $225-$250 and are made of cheap tin.ill let it go for $240.
