International 340 Hydraulic Filter Part Number
I have an 1958 International 340 Industrial with high capicity hyraulic pump.
Need to know part number for filter(s) and amount of oil in system.
I understand that there are three drain plugs to be pulled to get all oil out of system.
Any advice will be greatly appreciated.
Thanks in advance, Charles
As far as the filter there are a couple possibilities, if it still has the original metal filter housing, you can replace the two elements inside it with part number 375085R91 which is two new elements and gaskets, for about $35 or you can just replace the whole old metal filter assembly with with a paper style one which is part number 388084R93 and about $20.
Capacity I think is somewhere around 11 gallons.
