Hi the pump needs to have dial indicator to time
it have that and some paper work on it but does the keyway on the pump shaft need to be set in a certain way I now it is on the shaft only one way I mean when timing for tdc it has 3 bolts on pump and if any one has any inf on procedure ih said to set it at 14% befor tdc pump lift at 1MM on dial gauge Thank you
