Got a Farmall A - Plug wires all gone!! Mag is intact! When I hold my finger over the #1 cyl. and it pushes my finger out - where the rotor is pointed is #1 right or 180 off? but it is slightly BEFORE the plug wire hole - is that still #1 ? (no mechanic but learning - thanks !) [youtube is not much help - ha!] #1 is the cylinder closest to front right? firing order .. 1,3,4,2 ... #1 appears to have the rotor position .. just past the bottom of the distributor - so is #1 [ON DISTRIBUTOR] before or after where the plug wire comes in? I am probably as CLEAR as mud .. sorry . Thanks! Gary
