Oil leak on 1206 on bottom ?
larryanderson
Right where you would split a 1206 there are two removeable plates on bottom of tractor toward rear.One is thinner and smaller and that's were it appears hyd fluid is leaking.Its not black enough for engine oil which would make you think rear main.Probably something drive train related.Any ideas or will it have to be split? I had it at a show and just drove it home 20 miles as it was so nice and leak appeared. Fluid levels didn't show much difference. Thanks
does the plate have 2 bolts holding it on?
sounds like your transmission front seal is leaking, if that is it you will have to split it in half .
there is also a cover on the bottom counter shaft that is held by 3 bolts ande has a basket in it , if this leaking you should be able to change the gasket with out slitting the tractor.
hope this help
It will be either the seal around the IPTO drive or the seal around the input shaft leaking.Yes it is a split job done many.I'm sure Pete or Owen will chime in they can explain the process alot better that I can.I can do it but terrible at explaining things.
