My 1944 Farmall M stops moving/pto while mowing.
This tractor is new to me I have only owned it a few months and this is the first time i have used it for any operation.
So far i have changed all fluids and filters
Did a valve adjustment
cleaned/rebuilt carb
Converted to a Delco 10SI Alt 1 wire
Rebuilt starter
Installed 3 point conversion with twin lift cylinders
and other general service items
I am using a JD 390 flail mower weighs approx 950 lbs
The tractor runs and drives great and i cant get it to act up while just driving the tractor. But when i shift the PTO into gear approx 5-10 minutes into mowing the tractor just stops moving and the pto stops spinning. the engine continues to runs fine.
If i disengage the pto and shift into neutral, push the clutch in a few times the tractor begins to operate normally again. I can the re engaged the PTO and mow for another 5-10 minutes before it happens again. The only thing that concerns me is that i cant get the tractor to duplicate the problem with out the PTO engaged
No change if i hold the PTO shift arm up....This seems like a clutch issue. I just cant figure out why the clutch would only act up while mowing and not during any other driving operation in any gear.
Any Ideas?
Thanks for your help.
Rebuilt starter
Any Ideas?
