TractorLinks.com
Show Parts for Model:
Re: 706 gas engine not getting enough gas to pull
mkirsch
08-18-2014 07:02:26
With the fuel line disconnected at the carburetor you should be seeing a full stream of fuel out of the line continuously, with no sputters or dribbles or anything. Just straight fuel.
Also, "putting a carb kit in" is not a guarantee that the carburetor will work right afterwards. You've got to clean everything and put it back together correctly. Float setting is crucial, and the float is kinda delicate. If you ding it a little you can cause it to rub on the side of the carburetor bowl and then it won't move properly, and can choke off the flow of fuel.
