TractorLinks.com
Show Parts for Model:
Re: c113 valves
pete 23
08-17-2014 15:25:27
You need to use the same length valve you have. The longer one is for gasoline engine and shorter is distillate. The spring tension would be way off and your rockers would not contact tip properly.
calcubman
08-17-2014 20:33:29
 Re: c113 valves in reply to pete 23, 08-17-2014 15:25:27
the original ones i have are the shorter ones and it runs on gasoline, if i buy the longer ones the kit comes with new springs which i would assume they are suited for the longer valves.
pete 23
08-18-2014 18:15:52
 Re: c113 valves in reply to calcubman, 08-17-2014 20:33:29
Running on gasoline doesn't mean it is a gasoline head. Many distillate heads on those old engines running on gasoline. If the old valves worked properly you need the same length or you are in trouble. New springs won't change that.
calcubman
08-18-2014 18:44:29
 Re: c113 valves in reply to pete 23, 08-18-2014 18:15:52
i ordered the same length, so i wont have any problems, thanks
