TractorLinks.com
Show Parts for Model:
Magneto ID # H4245012
Farmallb
08-17-2014 14:09:48
When, or on what models would this mag have been put.
Does it take an internal, OR top mounted coil
john *.?-!.* cub owner
08-17-2014 19:22:21
 Re: Magneto ID # H4245012 in reply to Farmallb, 08-17-2014 14:09:48
On teh one pictured that is only a cover to keep dirt and moisture out of the magneto and away from the coil.
Tom Fleming
08-17-2014 18:26:04
The E4A had the coil internal to the armature. The F4, H4, and J4 had the coil separate, housed under the mag cover. The F4 mag housing is under the magnet. The H4 and J4, as indicated, is under the black, Bakelite cover.
Farmallb
08-17-2014 18:44:47
 Re: Magneto ID # H4245012 in reply to Tom Fleming, 08-17-2014 18:26:04
Does the black cover attach to the coil, or is it just a cover. On E Bay, I saw internal and the black covers, so I don't know if the black covers COVER the coil, or is a part of the coil.
Jim Becker
08-17-2014 17:20:30
Probably over 1 1/2 million. Number 245012 was built in August, 1941.
gene bender
08-17-2014 17:07:01
1939-1948 or so on A,B,H and Ms all used the same mags also W series and power units. Even Continetal used them on I-H Combines and balers so probably over a million were in use during 40s and into 50s
Farmallb
08-17-2014 17:41:36
 Re: Magneto ID # H4245012 in reply to gene bender, 08-17-2014 17:07:01
BUT, Question im trying to find out about is, IS the coil the black box on top that mag, OR is it internal.
John M
08-17-2014 18:08:30
 Re: Magneto ID # H4245012 in reply to Farmallb, 08-17-2014 17:41:36
Internal, under the black cover. Take out the 4 screws that hold the cover on, take out the 2 screws out of the coil rod, coil and all comes out.
John M
08-17-2014 15:01:30
H4 mag, will fit quite a few tractors. Maybe someone has the model it came from based on the serial number.
Tom Fleming
08-17-2014 14:17:10
That is a serial number, not a model number. any chance you can find the model? post a picture?
Farmallb
08-17-2014 14:29:45
 Re: Magneto ID # H4245012 in reply to Tom Fleming, 08-17-2014 14:17:10
There are no other numbers on it. Theres a oval iron plate on the R side, but its rusted over and I cant see anything on it.
IF you can post pics of them I can sure ID it. It has the black square bakelite? cap on top
Bob
08-17-2014 15:01:40
 Re: Magneto ID # H4245012 in reply to Farmallb, 08-17-2014 14:29:45
Sounds like it's a common H-4 mag that was used in MANY applications.
Farmallb
08-17-2014 15:33:05
 Re: Magneto ID # H4245012 in reply to Bob, 08-17-2014 15:01:40
IS that top black piece the coil? Im told the coil is bad on mine. The top piece, IF it is the coil, is 1/2 the cost of an internal coil, so Im trying to find out which one I need
Bob
08-17-2014 15:40:30
 Re: Magneto ID # H4245012 in reply to Farmallb, 08-17-2014 15:33:05
The mag's coil is cleverly hidden under that top bakelite cap.
Check out the service manual HERE:
http://www.cleancomputes.com/Cub/Blue%20Ribbon%20Service%20Manuals/GSS-5035%20Service%20Manual%20Magnetos/index.html
