400 farmall wfe
krob
Just a heads-up, my boy and I are trying to get a 400 back into working condition, so I hope we dont wear you guys out with questions. We have the front end out right now, waiting on a wide front. We found one off of a 706 that the man said would would bolt right under the 400. Is this true. If not, I'm not afraid of a few modifications, just wouldnt want a complete frame rework. It does have power steering so I think it will handle the wfe good enough.
It will bolt right on.However,you may have to drill (2) holes in each frame rail for the stabilizer.
Pretty sure the rear support that bolts to the frame rails is the wrong height. Need to make less high or shim pivot casting down.
