TractorLinks.com
Show Parts for Model:
c113 valves
calcubman
08-17-2014 11:21:49
would it make a difference if i replace the original exhaust and intake valves that are 4.83 long and replace them 4.94 long valves? both kits say they are for the c113 engine farmall b but the lengths are differnet the 4.94 are cheaper ?
Jim Becker
08-18-2014 06:28:17
 Re: c113 valves in reply to calcubman, 08-17-2014 11:21:49
I haven't checked the parts catalog on this, but I believe the valve springs are all the same. The upper valve spring seats (washers) should all end up in the same position. The valves are different lengths on the other end to compensate for different sizes of combustion chambers.
pete 23
08-18-2014 10:55:01
 Re: c113 valves in reply to Jim Becker, 08-18-2014 06:28:17
But the valves being longer they will extend farther over top of head and thus the tension on springs will be less, plus the geometry of rocker to valve will be way off.
pete 23
08-17-2014 15:25:27
You need to use the same length valve you have. The longer one is for gasoline engine and shorter is distillate. The spring tension would be way off and your rockers would not contact tip properly.
calcubman
08-17-2014 20:33:29
 Re: c113 valves in reply to pete 23, 08-17-2014 15:25:27
the original ones i have are the shorter ones and it runs on gasoline, if i buy the longer ones the kit comes with new springs which i would assume they are suited for the longer valves.
pete 23
08-18-2014 18:15:52
 Re: c113 valves in reply to calcubman, 08-17-2014 20:33:29
Running on gasoline doesn't mean it is a gasoline head. Many distillate heads on those old engines running on gasoline. If the old valves worked properly you need the same length or you are in trouble. New springs won't change that.
calcubman
08-18-2014 18:44:29
 Re: c113 valves in reply to pete 23, 08-18-2014 18:15:52
i ordered the same length, so i wont have any problems, thanks
gene bender
08-17-2014 11:42:07
No more length than that cant make any difference. o.11 will not even be noticed after the tappets are set
Bob
08-17-2014 14:57:50
 Re: c113 valves in reply to gene bender, 08-17-2014 11:42:07
WOW! That's nearly an eighth of an inch... (.125")! That's gotta change the valvetrain geometry a bit, doesn't it?
