Rear wheel wobble on Farmall 340
I noticed some rear wheel wobble on my 340 when driving it to a tractor show. Guys there said there is a technique to fix/reduce that wobble by jacking up rear wheel, loosing bolts that hold rim to wheel, and re-tightening and or using shims to straighten wheel. Any suggestions would be appreciated.
Irv
I sort of have that on a different Farmall, but I think my rears take a "set" and get slightly out-of-round, from sitting so long, not getting out and working.
Come to think, I guess I do too....
Are the rims running true and are the clamps correct holding the rims to the center as they could be mounted wrong or does just the tire wobble maybe the tire isnt seated on the rim even
Do as they said loosen the wedges and retighten them so they are tightened equally all the way around. You can set a block of wood on the ground along side tire and turn turn rear wheel by hand and see how true you have it.
