TractorLinks.com
Show Parts for Model:
Re: 460 utiltiy gas rough start...
El Toro
08-17-2014 06:48:24
You should pull off one plug wire at a time while a helper makes an attempt to start the engine to see if you have hot fire to your plug. If the fire looks weak your coil may be weak. Check your distributor cap for a crack. Do a compression check to see what your readings are
and check the valve lash to see if they have enough clearance. Make sure the helper has the brakes locked and the transmission is out of gear.
New points and a condenser may be in order. Hal
PS: APG is taking a cut in personnel somewhere around 5000. This is what our local paper has posted. The traffic is terrible in that area and not much better in Bel Air.
