TractorLinks.com
Show Parts for Model:
SMTA with Fast Hitch?
LA in WI
08-14-2014 05:22:17
Any SMTA tractors built by IH with Fast Hitch? Or add-on later?
LA in WI
GaryInKs
08-15-2014 21:13:38
 Re: SMTA with Fast Hitch? in reply to LA in WI, 08-14-2014 05:22:17
If I can find it, there is an ad for a new SMTA with fast hitch
IH fan
08-16-2014 06:48:32
 Re: SMTA with Fast Hitch? in reply to GaryInKs, 08-15-2014 21:13:38
I think it was originally intended to be a factory option on the SMTA, was never actually was. There may have been some dealer installed in '54, but other than some factory test machines, I'd bet non ever left the production line with a Fast Hitch.
gene bender
08-14-2014 11:20:50
Didnt come from factory but were added at dealers or later.
IH fan
08-14-2014 05:54:10
The larger size Fast Hitch did not come along until the 300/400 series, but they could be retro-fitted to a SMTA. IIRC, it was actually not the first 400 version that fit the SMTA though, but the 450 version... maybe someone can correct or verify that.
robgIN
08-14-2014 09:47:22
 Re: SMTA with Fast Hitch? in reply to IH fan, 08-14-2014 05:54:10
ours has the 400 style on it , I'll dig up some pics later
robgIN
08-14-2014 18:57:02
 Re: SMTA with Fast Hitch? in reply to robgIN, 08-14-2014 09:47:22
this is the only part that looks modified to install the top lift cyl bracket , I think they drilled and tapped a couple holes and welded the threaded rod. The piece of wood wired to hold the pin is a more recent mod , there used to be a curved piece if steel that actually looked like it belonged there , but it must have broke off at some point and this seemed to work at the time.
robgIN
08-14-2014 18:47:43
here are some pics
BOBM25
08-14-2014 08:29:42
No SMTA from factory with a fast hitch. 300/400 version will not work without major modification. 350-460 version also will not fit, as the mounting plates are too narrow. Needs to be from 450-560, then it'll bolt right up.
D Slater
08-14-2014 05:37:10
No regular production tractors came with a fast hitch.
