Super MD Fuel Strainer
DanMD
Is the fuel strainer that goes on the small starting tank on a SMD the same part number as the fuel strainer on the gas M"s?
Thanks,
Dan
I believe so... I used the same strainer on my MDs as I do on my gas tractors. The only issue I have found is the reproduction strainers don't always clear the bottom of the tank allowing you to open and close petcock. I had to gring the petcocks down on both of mine for clearance. Jim
Yes, it will work. I dropped fuel bowl down about 1 in. with an adapter from the hardware store so the shutoff would clear the tank.
