Gary Sweeten
New User
Looking for some input on steering box.
There are 2 15/16 threaded holes near shifter on left side as you are sitting on tractor. I need a picture of what those 2 plugs look like. On my Tractor that I just purchased (1) has a metal line approximately 1" in diameter the other is a open hole that has a rubber line going from top of I am assuming is the power steering block under dash looks like it is hooked to the steering shaft. I have pictures if anybody out there has an Idea what I,m talking about I could send. The hose coming from power steering unit is not a pressure line it is a by-pass line just going straight into the 1 5/16 hole with a rag around it to protect from moisture, dust Etc.
Thanks for your help Gary
