A question about a Farmall C cooling system
I have a 1948 Farmall C. I was wondering what type of radiator cap I should get. It does not have a water pump but there is a overflow tube coming from the top where the cap goes.
In the catalog they list a 4lb, 7lb, and non-pressurized.
Does this system handle summer temps well?
yes it does at least here in east texas i can mow all day in 90+ temps no problems i like having no water pump one less thing to need fixing
The pressurized caps (choose 7#) fit in a neck that looks like a regular car cap. It has cam flanges on the outside of the neck, and a gasket seat down in the neck an inch or so. The non pressure cap fits on like the gas cap. The neck has cam flanges on the inside. They are very different. Fill either system only an inch over the core tubes. There is no overflow reserve, and the excess will puke out. Jim
