Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 560 d valve adjustment
Owen Aaland
08-09-2014 17:22:21
Timing marks are on the front crank pulley with a pin sticking out of the front cover. When coming up on #1 both valves will be moving on #6.
When ever you see both valves moving at the same time, one closing and the other opening, on any cylinder, the cylinder just opposite it in the firing order will be coming up in the firing position. 1 & 6, 2 & 5, 3 & 4.
Jim Naden
08-09-2014 23:35:22
 Re: 560 d valve adjustment in reply to Owen Aaland, 08-09-2014 17:22:21
With #1 at TDC adjust valves 1,2,3,5,7 and 9
With #6 at TDC adjust valves 4,6,8,10,11 and 12
Clearance is .027" on all valves, set "warm" which is any temperature above freezing.
