Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
international574 not charging
jim23377
08-09-2014 15:13:05
My international 574 with d239 is not charging. I checked the wires they look good. Got the volt meter out and testested it with the engine off. 12 volts on one of the posts on top and on the charging lug. Turn ignition on and I now have 12 volts on the second post on top. Started engine revved to 1500 rpm. turned lights on and main lug on alternator is at 11.5 volts. Bought a reman alternator and same result. Am I missing something. I will get the alternator tested next week. Just can"t do it on the weekend. Thanks for any and all help
Owen Aaland
08-09-2014 17:45:23
 Re: international574 not charging in reply to jim23377, 08-09-2014 15:13:05
Early 574s use a 10DN alternator with external regulator. They use three wires on the alternator. A hot lead from the ammeter gauge, a ground wire, and a wire from the regulator on the F terminal.
Later ones use a 10SI alternator with the internal regulator. the gasoline models use a diode between the key switch and the #1 terminal. Diesel models use a resistor instead of the diode. The #2 terminal has a wire from the battery cable post on the starter. Thee wire connected to the output stud on the alternator comes from the ammeter gauge.
They all use a gauge rather than a light for charge indicator.
jimb2
08-09-2014 19:15:31
 Re: international574 not charging in reply to Owen Aaland, 08-09-2014 17:45:23
Hi Owen, a major difference in the early 574s delivered here in Canada still had Lucas generator with external regulator.
JimB
Owen Aaland
08-10-2014 01:53:10
 Re: international574 not charging in reply to jimb2, 08-09-2014 19:15:31
You have my deepest sympathies. :lol: :lol:
Owen Aaland
08-09-2014 17:12:22
I think you will find a problem with the new alternator. You had 12 volts on the battery stud and #2 terminal with key off. When you turned the key on you posted that you also had the same voltage on #1 terminal. That voltage should have been less since it has to run through a resistor before entering the regulator. From the #1 terminal it goes through the regulator and then through the brushes and coil in the rotor. The resistance in the rotor should be near the same as the resistor resulting in a voltage reading of about 4 -8 volts on the #1 terminal with the key switch on. The fact that the voltage is the same indicated that there is a problem with an open circuit internally in the alternator.
I have seen this problem a couple of times with rebuilt units. One time the grounding clip was missing on the regulator. Another time the protective sleeve was still on the slip rings keeping the brushes from making contact.
jimb2
08-09-2014 16:13:38
Hi Jim, what kind of alternator? 1 or 3 wire?
Internal or external regulator?
JimB
El Toro
08-09-2014 16:06:34
Have you checked the regulator? Hal
jim23377
08-09-2014 16:23:44
 Re: international574 not charging in reply to El Toro, 08-09-2014 16:06:34
I would say 3 wires two on top and the main lug on back. I think its a 10 si delco rami. Internal regulator
jimb2
08-09-2014 17:14:59
 Re: international574 not charging in reply to jim23377, 08-09-2014 16:23:44
Hi Jim,
Verify the wiring as per Bob Melville's diagram.
Just ignore the wiring to resistor going the coil as this is for gas engine. Originally your 574 would have had a generator and voltage regulator unless it was a very late model. Does it have an amp guage or is it idiot light only?
See: http://www.cleancomputes.com/Cub/Delco%2010SI%2012%20volt%20conversion.jpg
JimB
Copyright © 1997-2015 Yesterday's Tractor Co.
