ken house
i have a 130 farmall. it does not have a live clutch. put an over running clutch on it and was in process of hitching to bush hog. finally, i realized that the overrunning clutch is made for a keeper that is built into the yoke. the yoke on the bush hog is built for a pin to go through both yoke and pto shaft, on the over running clutch.
Is there a way to hold the pto shaft onto the over running clutch, without drilling a hole for a pin , or replacing yoke on pto shaft?
I had a similar situation on a MF. If I understand correctly. My MF had no hole in the PTO shaft. I had to buy an additional coupler extender, a female-shaft x male-shaft, I think made by Double-H-H, mayber $40 or so. Some farm stores that carry over-running couplers also carry this additional adapter.
It"s only money..
