Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Final potos and info for C-153 in Super C
Rex Simpkins
08-08-2014 18:51:54
Here are the last photos of it almost complete.
Used the following parts for archives
Rear Fuel Tank support from Famall "A"---49601D
140 Radiator---369400R94
140 Radiator brace--369513R1
140 Lower Radiator Elbow 369396R1
140 Upper radiator outlet--367679R1
140 Upper Radiator Hose 369397R1
140 Lower Water Pump Hose 387721R1
140 Lower Radiator Hose-20075DB
Had to use original fan off of power unit but had to remove 1 1/4" off the ends of each blade
WellWorn
08-10-2014 19:19:12
 Re: Final photos and info for C-153 in Super C in reply to Rex Simpkins, 08-08-2014 18:51:54
Thanks for the answers, Rex.
Rex Simpkins
08-11-2014 03:02:17
 Re: Final photos and info for C-153 in Super C in reply to WellWorn, 08-10-2014 19:19:12
Your welcome, good luck with your project.
WellWorn
08-10-2014 11:21:16
 Re: Final potos and info for C-153 in Super C in reply to Rex Simpkins, 08-08-2014 18:51:54
Looks good, Rex. Just a couple questions.
Is the SC sheetmetal going to fit, or will you need to use 'hundred series' metal to fit the radiator? Is the 153 block longer than the 113/123, i.e.: is the hood going to fit?
What about hydraulics? It's essentially what put the Super in SC.
Rex Simpkins
08-10-2014 18:46:40
 Re: Final potos and info for C-153 in Super C in reply to WellWorn, 08-10-2014 11:21:16
If you use the parts I listed the Super C sheet metal fits perfect. I removed the touch control from mine but the C153 has the hole for the hydraulic pump so it should be the same hook up a Super C. It was an easy project just a pain tracking down what parts would work--thats why I included parts and part numbers for the next person that comes along
jerry 4
08-09-2014 10:07:16
are you going to use a fan shroad{spelling}
you could run a electric fan, its a option.
Rex Simpkins
08-09-2014 11:18:34
 Re: Final potos and info for C-153 in Super C in reply to jerry 4, 08-09-2014 10:07:16
I am maybe going to put a shroud on it, I will use a 140 shroud and cut the top and bottom out and just use the side bolted to the rad.
IH fan
08-11-2014 06:30:51
 Re: Final potos and info for C-153 in Super C in reply to Rex Simpkins, 08-09-2014 11:18:34
I'd sure use a shroud if you can find or make one... we found it made a world of difference on a race car. There is almost no "suction" through the radiator without one.
Erik Dekeyser
08-09-2014 08:11:45
Nice job it looks real good. Using the 140 rad and parts is the easy way to do it i found. She should be a real tractor now.
