INTERNATIONAL 650D WIRING
thanks, but this site does not show wiring Diagram for a 1957 international 650 diesel with a alternator, negative ground. Help please.
Try the Porch Electric website. if it,s not shown I am sure they could help you with a diagram if you call them. I have purchased numerous harnesses from them and they are very helpful
Does anyone actually have a digram for that since the alternator and negative ground are not factory? Maybe someone does have a "custom" diagram that shows the modifications. I am going to watch this thread to see what replies come up!
Since you are using an alternator you most likely are not going to find a wiring diagram exactly like you want. Bob's diagrams will give you a good start. If you let us know exactly what type of alternator you are going to use and whether it will be a one wire connection or three wire we could give you some tips on what you will need. If you have a magneto rather than a battery ignition will also make a difference in what you will need to do.
Bob's wiring diagrams
