Three point on an older H
I have an older Farmall H that I would like to add an after market 3 point hitch to. The S/N plate is not readable but it has band brakes and a belly pump which works. I understand the Saginaw 3 point is not available. I want to use this tractor with a rear mount blade and also maybe a Danauser post hole digger. Does anyone have any suggestions as to what might be a good option? Saginaw was always said to be a good unit but they"re not available now.
Gene
Other 3 points are out there.If you're 'handy',you can make your own.Just pattern it after a 'commercial' hitch...take some measurements....I've made several for H/M.My current SH has one of my hitches,Works as good(Ithink better) than a 'store boughten'.I made my first hitch 30+ years ago on a SuperM.Still own the tractor,use it frequently,NEVER had the first problem.It's been used hard,too.
I have heard Saginaw is not producing hitches anymore. But you should still call them to see if they happen to have one in stock. From what I understand, they are still in business. They just stopped producing hitches. Likely due to the fact that they have likely already saturated the market and the poor economic conditions.
