Farmall 560 and 2MH corn picker.
I was curious if a no.2MH IH corn picker will mount on a 560 row crop. If its impossible I will then look dumb, I have an M but I wondered if the 560 will fit.
2MH pickers were built the same time the 450s and 560s were being built. It would make a nice combination with the 560. Also if you are going to use it, the 560 has live pto where the M wouldnt, unless it has hand clutch.
I don't know about a 2MH but I have used the same new idea mounted picker on both a 460 and a super M using the same mounts. I would try it.
A 2MH will fit a M through 806. As Gene mentioned, the finding correct brackets is the hard part these days. I would love to put my 2MH on my 460 and 2MHD on a 560, but the mounting brackets are keeping me from doing so, so they will stay on my M for now.
I have a set of brackets for a 450. Should be real close to a 560 as a 560 is basically a 450 with a 6 cylinder motor.
the middle belly bracket is differnt between the 450 and 560, I have seen both brackets and have read the parts book on these pickers, a 450 rear end is simular to a 560 but is not the same.
