c113 c123 valves
calcubman
would engine valves for a C123 engine fit in a C113 engine? the difference i see is the length, C113 is 4.83 and the C123 is 4.94. probably would have to use the valve springs for the C123 4.94 valves.i can get the valve kit for the C123 to put in my c113 for $50.00 . thats why i am asking. thanks
Check out a valve kit in the tractor parts on this site it might help.
Maybe there is a difference between the kerosene and gas head?
There is a difference in length between the Distillate and gasoline heads. The keepers and retainer will be in the wrong place if the wrong valve is used. The Gasoline head with the small chamber is a sure 4 hp improvement. Jim
You must get the correct valves. Ideally, if you can get a valve out and measure it, then order the correct set.
