Power Steering SWD-9
hopadoe
I tried the classified ads and did not get a single bite. Does anyone have or know where I can get a power steering setup for this tractor? thanks
I have some of the parts that you may need.. they are off a SW 6 THAT HAD A wd9 AXLE ON IT THAT I restored to original. LOCATED IN PRINCE GEORGE BC
600 and 650 are the same tractor for all practical purposes, and those would be equipped with power steering more often than the Supers or pre-Supers.
Problem is finding one with the power steering intact, in a parts lot. These tractors are rare and I would dare to guess that most all of them are in the hands of collectors somewhere due to parts being so hard to find.
If all you did was post a classified ad here, you haven't even scratched the surface yet. I equate that to needing a new toaster, looking out your front window, and saying "I can't find anyone that sells new toasters."
There is a guy that builds power steering kits, mostly for Ford tractors, but I think he has them for the W4, W6, W9, etc also.
He has a website, but I can't think of right now. Maybe someone else knows?
As an after thought, MAYBE you could adapt the power steering components from a Ford 900 series tractor, if you can find a donor tractor.
The guys on the Ford forums might be able to steer you to the website.
If the original poster isn"t, I may be interested in these. My email should be on this post. Thanks, Sam
does your tractor have the live hydraulic pump? I have one of those and a tank if you need one. I also have a 600 and 650 parts tractor if you need anything else.
