video of 354 lift problem
heres a video showing the line jumping on the 354 that is messed up.
http://vidmg.photobucket.com/albums/v174/chadfowler/MOV02223_zps121d72f8.mp4
The line jumps because the system is going "on demand," aka on high pressure, for some reason.
Probably a piece of something somewhere in the system.
Hi Steven, does the 3pt jump at the same time?
Can you hear the relief valve releasing?
Do you have a drawing of the hydraulic system?
I have one that I can take a photo of from B-414 Operator's Manual.
Please let me know if you require hydraulic drawing.
May not have time to post it until this evening.
JimB
yes the 3 point jumps at the same time not sure on the relief valve. i have seen the parts diagram layout on the case website other than that its all i have.
Hi Steven, with the draft control all the way forward and 3pt lift with no load on them am and raised half way does it still do same jumping of hydraulic hose? Did this tractor have a FEL installed at one time?
JimB
i have a bush hog on there now so i havent tried it with nothing on the 3 pt. far as i know never had a loader on it. [email protected] is my email, jimb what is your email i would like to send you some pictures and ask some questions if you dont mind. thanks
Does hitch settle when engine is shut off. If it does that is why your hydraulic is jumping to correct hitch. Otherwise, it would be in the unloading valve .
