Kevin in Va
New User
Working on a 1952 Farmall Super A, FAA SN 327054. The block has 3" bore sleeves and flat top pistons in it Casting number is 354898 R1. Casting date is 2-6-X, so it was cast February 6th 1954 from what I was able to gather. The serial number on the block is 328671 with an FAA with something that could either be an IV or a M. FAAIV or FAAM? There is also a "G" to the upper right of the serial number. There's no C-123 identifier cast into the block like some photos I've seen. The isn't any dipstick either. Just wondering as I'm getting ready to order a rebuild kit and would like to go to 3-1/4" with stepped pistons if possible. Thanks in advance.
