HillBillyRockStar
Putting new clutch in a M. Went from a 11" clutch to a 12". Flywheel from a 400. Flywheel resurfaced, New pilot and throwout bearings, reman clutch disk and pressure plate. Went together easy till rear engine plate was a 1/4" from bell housing. Pulled it back apart pressure plate hitting belly pump tank. Tractor has the live hydraulic pump on it, using belly pump as tank. Pressure plate is not splined like a T/A tractor. Pilot bearing fit imput shaft. Spline's on clutch disk fit also. So 1 of 3 things is going on. #1 12" clutch won't work in a tractor with a belly pump? #2 I ordered or using wrong clutch parts combination? #3 I ordered correct parts got sent wrong one's? Y'all the experts what did I do wrong?
