Super M governor
Heath72
I just bought a stage II Super M and the governor is acting goofy. I have idle and full throttle, but nothing in between. I'm not familiar with these governors. Is there anything in particular to look for when I take the cover off? Does this tractor have the same governor as a straight M?
M will work, remove side and top cover of governor to figure out what's going on. Should be able to see what the problem is. If needed you can remove the linkage pin under the top cover and pipe and operate the shaft by hand to make sure there's no problem with tube to carb. connection. Don't get wild because the engine can be over revved like that.
