460 560 mystery bracket
Nebraska Cowman
I found two of these. Not right and left but both the same. 1 1/8 id tubing and 12 in long. Any idea what they might be. They are marked "460 560"
Tubing size seems quite large for this, but I'll throw it out there. Another possibility could be for a row marker for a rear-mount cultivator. If the bolt pattern lines up with a frame rail, it may have had a rod with an offset to it that could be turned to line up with various row widths/spacings and tightened with the set screw.
AG
Howard,
Sure looks like the permanently mounted standpipe for the small grain auger that goes inside the truckbed for wheat planting.
Can't tell ya the manufacturer of the auger, but have got one in my truck right now. I'll try to remember to get a picture.
Allan
To me it looks like a home made umbrella bracket from looking at welds. It looks like it could be mounted on fender with the piece with one hole used for some sort of brace mounting.
Do they hold the Quicktach disconnect hydraulic couplers for a Westendorf loader on the frame rails.Think their missing the other part that holds the couplers.
Umbrella bracket for 460/560. Mounts on left side
sitting in seat right in front of dash. The long
flat piece with 3 holes bolts where white tin work
goes into cast corner, top hole bolts to dash area.
I have couple 560 diesels I work on and they have
them on tractor.
