806 steering
dpurvis
New User
son has 806. has steering at idle but is hard and makes screeching noise. as you raise rpm it gets worse, at 1900 rpm cannot move wheel. can drive forward or backward has brakes, three point works. front loader works, torque works with no slip. what should we look for? has sat for a month, last time used there was no problem. started this time its like this.
Can you tell where the noise is coming from?
Does the oil light work? Does it come on when you push in the clutch?
My guess would be either a failed steering relief valve or the priority valve orifice has come out causing all flow from the MCV pump to go to the steering instead of only 3 gpm.
he has had tractor for 5yrs. he says the sender was unhooked when he got it home, so he hooked it up and the light has always come on when clutch is fully pressed, up an inch and it goes out. but the tractor has worked flawless till now. thanks owen for responding.
