Farmall a carb to air cleaner
I just got a new to me farmall a that is missing the rubber hose from the carb to the air box. Does anyone know the size of it? It's leaking gas out of if which I assume means I need to rebuild the carb because the float is sticking
Try using a tape measure to measure the outer diameter of the breather tube or carb throat. 2 1/4 inches diameter maybe?
The OD of the airhorn on the carb on my "A" is 1-5/8" (measured with an electronic vernier caliper).
It's best to get the correct (gas-resistant) hose, as ordinary radiator hose swells and rots over time, used for this purpose.
Perhaps THIS site sells the hoses (I haven't looked), or, likey some other restoration places do.
I have bought them for an 8N Ford, but I can't recall for sure, who has them for IH's.
