Rockauto Parts - Crossing Numbers
RTR
Need some help crossing part numbers for my Farmall. I have entered the IH number in the Napa crossover and got the parts I need, but I am about to make a RockAuto order (cheaper) and would like to get a bunch of Farmall stuff in that order since they offer Free Shipping. I tried both the Napa number and the IH number in the Rockauto site and got no results. Any help would be appreciated!
(quoted from post at 04:58:22 07/22/14) Might get a little more help if you posted the name of the part,
what it would fit, the part brand & the part number.
Parts for Super A tractor. Plugs, points, condenser, coil, rotor, dist. cap, oil filter, front timing cover gasket set (found), front engine oil seal, and maybe a few other parts. I need the front engine parts and wanted to stock up on other commonly used items while I was ordering .
(quoted from post at 06:26:38 07/22/14)
Anyone know a GOOD part number for the rear axle/final drive oil seal for a Farmall 140 and a Farmall Cub tractor?
What makes you think you can get that stuff at Rockauto? (re: "Plugs, points, condenser, coil, rotor, dist. cap, oil filter, front timing cover gasket set (found), front engine oil seal, and maybe a few other parts")
If they're selling tractor parts that's news to me.
(quoted from post at 22:27:43 07/25/14) What makes you think you can get that stuff at Rockauto? (re: "Plugs, points, condenser, coil, rotor, dist. cap, oil filter, front timing cover gasket set (found), front engine oil seal, and maybe a few other parts")
If O'reilly Auto and Napa carry these "common" parts I would think Rockauto would. I've found the gasket set by typing in the Napa number but the other Napa numbers or IH numbers I've tried don't cross. With Oil Seals especially, Rockauto should have them since they are probably common to other applications. Basically I'm saying that if they carry brand names such as Fel-Pro and National, then you'd think they'd carry any part those brands offered.
Just wondering if anyone had any known good part numbers that they knew that fit besides the IH number.
Just figured out that if you cross the IH part number on the O'reilly Parts website, then use their part number in the Rock Auto Site it'll pull alot of the parts up. Looks like they carry alot of the parts I mentioned.
I'd be nice to make sure those replacement parts actually fit correctly....so if anyone on here has expierence with the O'reilly crossed parts fitting ok, let me know. Mainly talking about oil seals.
