Farmall B clutch bearing
calcubman
i need to change the clutch throught out bearing on
my B and the pin that hold the yoke has a cotter key
i removed that but how to you get the pin or yoke
shaft out of the housing? it only has one hole on
one side. i have seen some with o hole for the pin
that goes through both sides of the clutch housing
I have a "39 "A" with no starter and it also only has one hole in the torq-tube. All the A's and B's that I have with starters all have two holes.
