Sleeve puller
DanH
Does anyone know here I can buy a sleeve puller for my farmall m. Or maybe you could share with me on how to build one that you have used . Thanks
I used 5" O.D. schedule 40 aluminum pipe, 3/4" high tensile fine threaded rod and 5" aluminum bar stock with a step in it for a cap on top of pipe and turned down a piece of 4.5" aluminum bar stock for the puck to pull sleeves. Adjust your sizes to your bore size and length of cylinder.
You can look on OTC tool site and buy the pucks , just have to know what size you need if you can't make one or have one made. The rest you can usually make with a piece of threaded rod and some scrounged up steel.
just take the sleeve to a machine shop and they will build you a puck on a lathe for about a 100.00. the rest you can build if you are a welder. BUT...if you are a welder just run a couple beads from btm to top across from each other and they will pull out with your fist.
