W4 Brake axel seal
Olie
Does anyone know where I can find a brake axel seal for my W4. I can't find a part number on the old seal, so I can't cross reference it.
(quoted from post at 10:51:07 07/18/14) Does anyone know where I can find a brake axel seal for my W4. I can't find a part number on the old seal, so I can't cross reference it.
I don't have the number handy, but it should be the same seal as used on an H. Bull pinion oil seal.
If it is the same as "H", here"s my info on my "H" seals;
Chicago Rawhide number, however they were not rawhide, just ordinary-looking metal seals with spring-loaded rubber tip-seal. Replaced all four CR seals.
„X Chicago Rawhide # CR-541901-USA
„X Case-IH CNH # 76510-C-91 [$22.10]
„X NAPA¡¦s # SKF-23184. [$15.49] [ 3.500¡¨ OD, 2.313¡¨ ID ]
Wound up as follows;
Right Side = I damaged / bent the new CNH seal, so I followed it with a NAPA seal.
[Drove the CNH seal in with a wood block, and bent the inner flange.]
Left Side; I installed the CNH seal OK, but followed it with a new NAPA seal anyway. [Drove the NAPA seals in
with a 3x2 PVC/DWV plumbing fitting.] Packed the seals with red wheel bearing grease before installation.
TO INSTALL SEALS;
Do not try to use rounded-off wood block. Seals are a tight press fit, and you cannot hit on the flange.
Tap the seal into place with the white 3x2 PVC plumbing bushing fitting in ¡§H¡¨ box.
