Farmall C implement bolt size and pitch?
48C-MAN
Looking for the size and pitch of the small side implement bolts on a Farmall C? The ones in the casted square on both sides.
If you're gonna play with 'old' tractors,that is a skill you need to learn.To be able to identify/figure out bolt size on your own.There are only 2 pitches in those bolts.Fine and coarse.VERY easy to distinguish.No metrics on old american tractors.Use a ruler/tape measure to determine the hole/bolt size.Grab a bolt or two and test itr to make sure,measure the bolt if you need to.With a bit of practice you will be able to just look at it and imediately know size/thread.Yes,I know what size ytou need. But for the sake of your furthering 'education',I will let you figure it on your own.For if I tell you,you wont learn a thing about about working on your SuperC or old tractors.That is a basic skill.If you still have trouble figureing it out(it's not hard),post back.Sorry for seeming to be an 'A...hole',but Just trying to help you become more educated/proficient/confident in old tractors.
When I am at work an hour away from where my tractor is parked at home just looking for a quick trip saver, now that being said just looking for the size and pitch.
If you had said you were a ways away from the tractor,That would have been different.I would have told you.By the wording,it conveyed(to me) you were too'lazy' to find out on your own.Sorry to have offended you as that was not my intention.I'm all for helping people.But I'm also a big advocate in teaching people new/more skills and to become more self suficent.BTW,The bolt in question is a 3/4 coarse thread.About 2inches long.
Yes, the bolts are 3/4" coarse thread (aka NC, which does *NOT* stand for North Carolina, BTW).
5/8" NC are for Farmall Cubs.
The bolts are 5/8 diameter and have a thread length of 1 1/4 inch. The thread pitch is NC (course).
For reference the part number is PO25842A. They have a tapered seat to help prevent backing out. If you search eBay for "farmall fertilizer implement mounting bolt" you will find both new and used bolts.
When looking at the implement mounting bolts you sometime see shorter tapered seat bolts sold as implement mounting bolts, they are actually drawbar mounting bolts with are slightly shorter in length.
hope this helps
Bob
The 2 bolts on the square pad on the bell housing on mine are 5/8 x 1 1/2" coarse but not tapered, it's got my #72 frt blade on it now and don't think the brkts. are for a tapered bolt. The pads on the side of the bolster are tapered 3/4 x 2" and used for a planter or cultivator
