C Kain
Hi, I have a IH W4,1953. Can someone give me advice regarding removal of the starter. Removed bolts, it moves a bit but seems to be hanging up on something. Thank You. C Kain
if it is the year you say should come out . on the earler ones had to take pulley drive off. later they cut corner off pulley driveto clear starter.
If it just will not come out, You can partially disassemble it to get it out. (leave the brush end and armature in the field, then take off the drive housing. Jim
