brake pedals
How is it stuck?
Spray some PENETRATING type oil such as PB Blaster or Kroil on the pivot points and work the pedal back and forth. Keep spraying and working until the pedal is loose again.
Sometimes you will need to heat up the pivot point with an oxy-acetylene torch.
It all depends on what's stuck, though...
There are 3 or 4 zerks under the floor on the brake shaft. See if you can force grease into them along with the PB blaster etc . Heat will help...
