560 bad pump?
So, I broke the pto shaft on my allis 6680 yesterday, so I hooked the discbine to my 560 gas. At first, it would lift the mower. After I made a couple of rounds, it would only lift it halfway, and very slowly. It would still operate the hydraulic swing on. What do you think?
A 560 doesnt have enough poop to raise a heavy haybine.Run a pressure test at the remote. then you will know the condition of your pump.However,the reduced lift after it gets warm is indictive of a worn pump.
(quoted from post at 02:24:16 07/13/14) A 560 doesnt have enough poop to raise a heavy haybine.Run a pressure test at the remote. then you will know the condition of your pump.However,the reduced lift after it gets warm is indictive of a worn pump.
hat should the pressure be?
