Question for Blackstack
Dear Sir: you evidently have a 460 and have gone into it to take the hydraulic pump off...I have done the same. Could you possibly tell me if the large gear that drives the small gear on the pump, has some "wobble" back and forth? And then, too, to get at the half-inch bolt that holds the gear on, do you know how to remove the large pipe-thread plug that is just a couple of inches forward of that screw? I think the plug has to be removed to access the screw. Thanks. Hugh
