Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: M - removing starting hand crank
S2710
07-10-2014 08:03:06
[quote="rustyfarmall"](quoted from post at 14:21:50 07/09/14) [quote="IAtractorKid"](quoted from post at 17:47:46 07/08/14) I beg to differ. I just installed the crank pulley
for a charlynn system on an M less than a month ago
and it will slip in without moving the front bolster
at all. In his case I think he will need to move it
forward a few inches to get that double pulley off.
Rust depending it shouldn"t be too bad of a job.
[img]http://photos.yesterdaystractors.com/gallery/uptest/a162515.jpg[/img][/quote]
Yours may have fit. Mine DID NOT.[/quote]
Rusty what did you do to get your fan to clear the pulley on the power steering pump? Also how did you reinstall the water pump drive? Thank You.
Bob
rustyfarmall
07-10-2014 14:24:57
 Re: M - removing starting hand crank in reply to S2710, 07-10-2014 08:03:06
I did not install the Charlynn power steering pump. Instead, I installed a Vickers, vane style pump. I built my own mounting brackets. The belt to fan clearance was a little close. 2 of the blades had sifficient clearance, 2 did not. Go figure. I chose the easy way out, and figured that if 2 of the blades cleared, then the fan must be bent already, so I "adjusted" a little more clearance into the remaining 2 blades. I think there is supposed to be a spacer that fits between the water pump hub and the fan, but I did not have one, nor did I know where to find it.
