1086 injector pump leak
gbs
our 1086 has developed a leak where the guide pin for the cam follower I guess you would call it goes thru the aluminum housing the pin has been staked in tight but has been cleaned and sealed with epoxy twice and it still will seep just enough oil to make a mess,is there anything else that will seal it or is a housing change the next step, the pump works perfect
