TractorLinks.com
Order Farmall Cub Parts Online
Re: Farmall Cub Sickle mower Pittman Arm
agauthier
07-09-2014 18:46:15
It looks like a complete set of parts. I think the top mechanism is upside down in the picture, if that helps.
If the spring really is too short for the hole in the pitman arm you have, it would seem that putting a plug or some washers in the hole would help the spring apply pressure. The plug might need to have a hole drilled down the center to accommodate the shaft.
At any rate, the mechanism should squish down pretty tightly onto the ball head-end of the knife. I keep a screwdriver handy to push into that little hole on the side of the clamp mechanism, which then provides leverage to open and close the clamp. To fully close the clamp on mine I need to first push it most of the way with the screwdriver, then step on the flat tongue that sticks out toward the knife. You shouldn't be able to open it with your fingers.
Good luck, and happy mowing!
agauthier
07-10-2014 15:12:13
 Re: Farmall Cub Sickle mower Pittman Arm in reply to agauthier, 07-09-2014 18:46:15
Not an easy part to show in a picture, but this is how mine looks when it is on and tight.
This is 60 years of haying for this old mower, by the way, cutting the same twenty acres over and over in NH. It connects with a fast hitch to a Super C, both always stored in the barn.
rhatch2nd
07-09-2014 20:25:32
Thanks for the help. I will see if I can make it work now. It is much clearer.
