TractorLinks.com
Show Parts for Model:
Re: Super C Hydraulic Pump Sticking
pete 23
07-09-2014 18:43:41
In behind the battery box, back side of hydraulic control box is a small pipe plug. Under that plug is a screw driver headed orfice. That is the first thing I would look at. The orfice has a screen on it and if most likely plugged restricting the flow through the orfice. The flow through that orfice is what moves the unloading piston to return the system to low pressure standby.
agauthier
07-10-2014 14:59:57
 Re: Super C Hydraulic Pump Sticking in reply to pete 23, 07-09-2014 18:43:41
Pete--is the plug you are describing accessible without removing the battery? I read in the manual that there is a screen behind the "touch control" sensor (lower left in this photo), so I pulled that out--it is huge ... a fat tube maybe six inches long. No idea what the correct procedure would be to clean it ... I just wiped it off and put it back.
So, I guess I didn"t find the plug you mentioned. Do I need to pull out the battery and remove the battery box?
agauthier
07-10-2014 02:00:56
Thanks, Pete. I will check this out. Provided I can find the right pipe plug, of course.
