Farmall 706 oil dip stick and tube.
Freddy
Finished up the engine swap on the 706 with a 301 / 715 combine engine. Run great. Ended up using a Zenith new old stock carb. My problem now and with the original carb is the oil dip stick is under the carb. Would any one happen to have a oil dipstick and filler tube for a gas 706/806 they would like to get rid of? They are extended out and curved. Thanks.
It was a diesel and it different. Nothing in the way on a diesel. Carb is in the way on a gas so it"s filler tube is S shaped! So it can snake out from under the carb . No longer available from cnh!
ok now I understand. I probably have or had the parts. Wouldnt know where to find tham or they may have gotten junked. Check on Ebay. 706 and 806 are the same. Good luck
