Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
international 354 leaking hyd oil in front of seat
steven in tn
07-09-2014 11:45:22
my 354 just started leaking hyd oil in front of the seat around the block. it is leaking in atleast 3 different places. it is causing pump to hum and jump sometimes constantly some time every few secs. the lift stays up after turning tractor off. i have the picture marked in three places the top two places you can see ooze out when the pump jerks and the bottom not sure where it is leaking, just see it running out of the bottom corner. any ideas?
steven in Tn
07-20-2014 03:56:32
 Re: international 354 leaking hyd oil in front of seat in reply to steven in tn, 07-09-2014 11:45:22
i got all the orings ordered for it i hope that fixes it that is all i know to try.
steven in Tn
07-12-2014 19:51:12
any more ideas anyone?
steven in Tn
07-11-2014 05:58:17
i rebuilt the piston last year becuase the lift would leak down and everything has been working smooth untill i was bushhogging the other day and it started leaking. i took the orifice out but it was clean. i cleaned everything thing up real good and new hyd oil when i rebuilt piston last yr. reservoir is not building up pressure.
jimb2
07-09-2014 16:44:28
Hi Steven, there is also an orifice screen on the input behind the large plug on the lower right of the top bolt that you have marked in your photo.
Remove the screen and clean it.
JimB
jimb2
07-09-2014 13:42:27
Hi Steven, has the hydraulic reservoir become pressurized? Either by the suction filter becoming clogged or some internal leak. Loosen the filler plug and see there is a pressure build up.
JimB
stevin in tn
07-09-2014 14:50:23
 Re: international 354 leaking hyd oil in front of seat in reply to jimb2, 07-09-2014 13:42:27
i took plug off to check fluid level and didnt notice no pressure.
Copyright © 1997-2015 Yesterday's Tractor Co.
