TractorLinks.com
Order Farmall Cub Parts Online
Re: Cub carb problem
mkirsch
07-09-2014 05:38:04
First off, the tractor will run better right side up.
Second, the main metering jet is under that plug that's on the top left of the carburetor in the picture, near the engine oil dipstick.
It is a Zenith carburetor, used as a replacement on early Cubs and stock on later Cubs. The specifications for it are not in the IH service manuals, but you can find them online.
Your problem is more serious than a simple adjustment if you have to hold the choke to make it run. That is fuel flow or an internal blockage in the carburetor itself.
If just cleaning the main metering jet does not help you will need to take the carburetor apart, clean it, and put a kit in it.
Cubluvn8n
07-09-2014 05:57:58
 Re: Cub carb problem in reply to mkirsch, 07-09-2014 05:38:04
Thank y"all for the help. I"m not sure why my picture is upside down, it is right side up on my device.... I defenatly wasn"t standing on my head when I took the picture! Are the zenith carbs better that the original ones?
