TractorLinks.com
Order Farmall Cub Parts Online
Farmall Cub Sickle mower Pittman Arm
rhatch2nd
07-09-2014 04:29:56
Hi,
Can someone tell me if I am missing a piece for this Pittman assembly. I cannot get this to stay attached when I engage the PTO. It seems as if I need something to make the spring functional and put pressure on the latch. Up till now I just had the spring arm going into the hole at end of wood Pittman arm.
Thanks,
56 Fan 400
07-16-2014 12:29:34
 Re: Farmall Cub Sickle mower Pittman Arm in reply to rhatch2nd, 07-09-2014 04:29:56
Saw a pic of just the pittman arm on ebay...arm and both ends attached with the spring. 1 john deere no. 5 sickle mower pittman arm with new bushing.......
I think I could repair or replace broken parts on my own for that kinda money.
agauthier
07-09-2014 18:46:15
It looks like a complete set of parts. I think the top mechanism is upside down in the picture, if that helps.
If the spring really is too short for the hole in the pitman arm you have, it would seem that putting a plug or some washers in the hole would help the spring apply pressure. The plug might need to have a hole drilled down the center to accommodate the shaft.
At any rate, the mechanism should squish down pretty tightly onto the ball head-end of the knife. I keep a screwdriver handy to push into that little hole on the side of the clamp mechanism, which then provides leverage to open and close the clamp. To fully close the clamp on mine I need to first push it most of the way with the screwdriver, then step on the flat tongue that sticks out toward the knife. You shouldn't be able to open it with your fingers.
Good luck, and happy mowing!
agauthier
07-10-2014 15:12:13
 Re: Farmall Cub Sickle mower Pittman Arm in reply to agauthier, 07-09-2014 18:46:15
Not an easy part to show in a picture, but this is how mine looks when it is on and tight.
This is 60 years of haying for this old mower, by the way, cutting the same twenty acres over and over in NH. It connects with a fast hitch to a Super C, both always stored in the barn.
rhatch2nd
07-09-2014 20:25:32
Thanks for the help. I will see if I can make it work now. It is much clearer.
lcc123
07-09-2014 05:20:33
It is complete sort of. You need a new spring. Yours is about half the length it should be. --Lee
rhatch2nd
07-09-2014 06:36:45
 Re: Farmall Cub Sickle mower Pittman Arm in reply to lcc123, 07-09-2014 05:20:33
Hi,
thanks for the help. So is this why I don't have any tension on the spring when I put it in the end of the rod? Where would find one of those new springs?
BillOHIO
07-09-2014 07:59:59
 Re: Farmall Cub Sickle mower Pittman Arm in reply to rhatch2nd, 07-09-2014 06:36:45
Appears that it is still available from Case/IH Dealer. Part # MA 1574 in the $10 price range.
Bill
